Installation & Licensing
Never Install Product Suite Before, HELP!
1 REPLY 1
TrevN
231 Views, 1 Reply
Hi All,
This is the first time I have tried to install a product suite and I can't get going, so be gentle!!
So, I have downloaded all the required files to a server.
I then extract the first file to my C: drive but I get the error message "This installation package cannot be installed by the Windows Installer Servce. You must install a Windows service pack that contains a newer version of the Windows Installer service"
Is there something I am doing wrong or do I need this service pack?
Or do you extract all filles to C: drive first then hit the setup exe?
Ta
PC Spec is as follows:
Windows XP Professional x64 Edition Service Pack 2 (build 3790)
Install Language: English (United States)
System Locale: English (United Kingdom)
Board: Hewlett-Packard 3031h
Serial Number: CZC9480N7X
Bus Clock: 800 megahertz
BIOS: Hewlett-Packard 786G1 v01.16 03/05/2009
2.60 gigahertz Intel Pentium Dual-Core
64 kilobyte primary memory cache
2048 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
8060 Megabytes Usable Installed Memory
250.05 Gigabytes Usable Hard Drive Capacity
80.37 Gigabytes Hard Drive Free Space
1 REPLY 1
DarrenP
in reply to: TrevN
if this is 2014 you can't install on XP unless you hack the setup.ini
system requirements: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=16490792
DarrenP
Administrator Productivity
