So this means that the Novell OS software could potentially still be used
when we go to upgrade. Then in order to use the network licensing software,
set up a work station to handle this duty ... would this workstation need
any OS upgrades, or will WinXP Pro be sufficient?
"Mike Donahue" wrote in message
news:407ae101$1_2@newsprd01...
> "Efim Tetelman (Autodesk, Inc)" wrote in
> message news:407addce$1_1@newsprd01...
> > Hi Mike,
> > FLEXlm runs fine on any Windows OS (server or workstation), there is no
> > limits to 10 connection for FLEXlm on server nor workstation, if you
check
> > dictation on this same news group "Limit to 10 users" you will find out
> > that
> > people running 100 licenses on a workstation at the same time and they
> > never
> > had any problems.
> > Hope it helps.
> > Efim
> Interesting. Saw that. By default, Windows should refuse any connection
> requests over the count of 10. The flexlm heartbeat must not be active
> enough to conflict with that setting. I would feel uncomfortable running
> 100 stations, myself though.
> Maybe this has morphed into something hard-coded in 2000 into a EULA item
in
> XP?
> Here's the relevant MS articles.
> XP: http://support.microsoft.com/?kbid=314882%22
> 2000: http://support.microsoft.com/default.aspx?scid=kb;EN-US;122920
> Mike
