Installation & Licensing
LisaDrago
Message 1 of 16 (252 Views)
Network not seen during installation
252 Views, 15 Replies
09-20-2013 10:48 AM
Working at a clients office setting up a network license... Don't this so many time I can do it in my sleep but this one has me baffled...
Okay we have the NLM set up correctly and working, go install the software on the computer... But it won't see the server! We have tried browsing to it... Nothing, typing it in ... Nothing.
If we go through windows explorer we can see the server - what are we missing?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
You are not allowed to be mean to me anymore!  :smileyvery-happy:
Glad you are up and running Lisa.  Nothing wrong with self-deprecation.  We all have our moments.
dgorsman
Message 2 of 16 (248 Views)
Re: Network not seen during installation
09-20-2013 10:52 AM in reply to: LisaDrago
Quick clarification - are you having trouble locating a deployment on a server to install on the local computer, or seeing the LM server?  If the latter, can you ping the LM server?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
TravisNave
Message 3 of 16 (242 Views)
09-20-2013 10:55 AM in reply to: LisaDrago
Lisa,
You can try IP address.  Regardless, even if the installation won't see it, you can still install the software and get the licensing to work afterwards.  Sometimes the browser service or DNS or even latency can cause this.  But its manageable once the software is actually installed.
Beyond that, so long as you can PING the server, get a valid IPv4 address, and have ports 27000 and 2080 open, you should be good to go.
Update us as needed.
LisaDrago
Message 4 of 16 (237 Views)
09-20-2013 10:57 AM in reply to: dgorsman
Okay - we can ping the server without any problems.
We are at the installation point of the software where it asks for network setup - we try to browse to it and can't see it and when we. Type it in - it just sits there and the next button is not active.
DarrenP
Message 5 of 16 (234 Views)
09-20-2013 10:58 AM in reply to: LisaDrago
try typing \\servername then hit browse
LisaDrago
Message 6 of 16 (233 Views)
09-20-2013 11:02 AM in reply to: TravisNave
We tried the IP address and it still will not activate the next button.
How can we check the ports? Trying to look it up - have not done that before...
DarrenP
Message 7 of 16 (231 Views)
09-20-2013 11:03 AM in reply to: LisaDrago
The FLEXlm® based version uses the following ports:
TCP ports 2080 (for the adskflex vendor daemon)
TCP ports 27000 to 27009 (for the lmgrd master daemon)
DarrenP
Message 8 of 16 (230 Views)
09-20-2013 11:03 AM in reply to: DarrenP
don't know what other ports the deployment uses
LisaDrago
Message 9 of 16 (229 Views)
09-20-2013 11:04 AM in reply to: DarrenP
We have tried this and it did not work...the \\servername
DarrenP
Message 10 of 16 (209 Views)
09-20-2013 11:07 AM in reply to: LisaDrago
do you know if they are running any type of security software?
you can try disabling that on the server
