Installation & Licensing
Network License via Air Card and VPN vs Wi-Fi and VPN
2 REPLIES 2
GTVic
432 Views, 2 Replies
We have a user that can connect and get a license using VPN over Wi-Fi.
But when he uses an Air Card (wireless cellular netword adapter) also with VPN he cannot get a license -15.570.0 "a valid license could not be obtained".
He is able to ping the license server host name over the Air Card VPN connection. Average ping time is 192ms but I assume the Wi Fi would be similar or worse so I'm not sure that cuold be the issue.
Any ideas would be appreciated.
2 REPLIES 2
TravisNave
in reply to: GTVic
Latency is notorious for air cards. Use the FLEXLM_TIMEOUT system environment variable. Start with a value of 1000000 and increase it by one-million until it works.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dembkod
in reply to: GTVic
GTVic,
Hello. VPN connections can be tough. Start with the Timeout variable and then try to enter a directional variable. I would insert both the IP and the Server name as well, separated by a semi-colon “;”
1.)           Right-click the My Computer icon.
2.)           Click the Advanced tab.
3.)           Click "Environment Variables".
4.)           Under the System Variables window, click "New".
5.)           In the Variable name field enter ADSKFLEX_LICENSE_FILE
6.)           In the Variable value field enter @YOUR_SERVER_IP_ADDRESS;@YOUR_SERVER_NAME
7.)           Click "Okay".
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
