Installation & Licensing
303 Views, 2 Replies
Network License Files
Is there a way that I can request new licence files for networked licenses. These licenses have been used previously and are already activated so I don't know if I want to re-activate them.
2 REPLIES 2
AllenJessup
Not exactly sure what you're asking but...
If you're talking about installing new seats of the program on new/replaced workstation - You can install as many times as you want from the deployment. You'll still be limited to the number of licenses you have.
If you need a new license file because you've had to replace the computer you're using for the license server - You'll need to get new licenses from Autodesk. This shouldn't be a problem because they allow for things like this. You're not re-authorizing them like if you had a stand alone license, you're just getting a replacement file. If you have any problem try contacting your reseller.
Allen
Allen Jessup
CAD Manager - Designer
TravisNave
Agreed. It sounds like you are describing stand-alone licensing and instead of network licenses. Are you getting any specific error?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
