style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"nickseman" <Hi:
href="mailto:nickseman4935@cs.com">nickseman4935@cs.com> wrote in
message
href="news:f12bf9a.-1@WebX.maYIadrTaRb">news:f12bf9a.-1@WebX.maYIadrTaRb...
Last week at AU I was told that I could somehow use ADSKFLEX in the
environment variable, instead of LM_LICNESE_FILE, to aliveate some problems I
was having when the client machine had other FlexLM software loaded on it. I
am not sure how to do that - any insight would be appreciated.
Thanks;
Nick
Jerry,
Which location is ADSKFLEX_LICENSE_FILE to be placed...
HKEY_LOCAL_MACHINE\SOFTWARE\FLEXlm License Manager
or
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Session Manager\Environment
Thanks in advance...
Tim
read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
DarrenP
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14374530&linkID=9240617
looks like both locations would be used...not sure why though.
Also, I'm getting conflicting info...ie on JTB, they state that you should use 27000@server instead of @server.
Tim
i've only used @servername
never had a problem
DarrenP
I don't see a problem either, but is one faster than the other if the WAN is worldwide?
it wouldn't hurt to test it on one machine
DarrenP
The NLM connects to 27000 to lmgrd by default anyway, so it's not really going to make a difference. On a WAN, you'll want to add the FLEXLM_TIMEOUT variable as well to overcome latency.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7574782&linkID=9240617
yup...found that out and I have it set FLEX_TIMEOUT 1000000.
Thanks for the links as well...
I love it! Each time Autodesk relaunches their homepage non of the links work anymore.
I guess a few month ago this would have been a very helpful thread to me. And now?
Thanks Autodesk...
Mario
Agreed. I am not a big fan of the change w/o appropriate redirects. In any case, as complains come up, I will try to provide the new links:
Good Luck!
