Installation & Licensing
Network license FATAL ERROR
7 REPLIES 7
Message 1 of 8
613 Views, 7 Replies
We had AutoCad Map 2000 Release 4 installed on a Windows NT 4.0 Workstation
version using a hardware lock (dongle).
Now we want to share that license around on several desktops.
We received a single network license code for this machine and installed
it.
Adlm is running and says we have 1 license, 0 in use. So far so good.
The PC is not an NT server, just a PC on a LAN with NT workstation
installed.
No autocad service packs are applied.
The system uses a static IP address and TCP/IP.
The system dates on all pc's are the same.
The dongle or hardware lock is no longer on the adlm license server machine.
The ACADSERVER variable is set on the license server: ACADSERVER="PC-HYLITE"
The server and clients are all on the same LAN, subnet.
We placed an image on the license server PC (called PC-HYLITE) for
deployment and then from the shared directory installed the client version
on another PC (called MADMAX) (tried both a client windows NT 4 workstation
and client Win 2000 workstation actually).
When we start the autocad map 2000 from the client PC's it fails with the
following error:
Fatal Error: Security system ( hardware lock or network license ) is not
functioning or is improperly installed.
The ACADSERVER variable is set on the clients as: ACADSERVER="@PC-HYLITE"
The clients can ping the server by name or IP.
Note that the PC's NetBIOS name or identification is PC-HYLITE (the adlm
server) and can't be entered in lowercase, even though the PC's TCP/IP DNS
related name is pc-hylite (lower case). In any case both upper and lowercase
names can be pinged from the client.
adlm is installed on D drive (also tried C: to no avail)
Using the License Query tool from a CLIENT
(installed on server, executed via network shared drive from client):
Servers
License Server Host Status
pc-hylite Active
Clients
Server PC-HYLITE:
172: 1 license , 0 in use; installed May-18-01
Environment
Host: MADMAX
Network Address: XXX.YYY.5.220 (IP edited)
License server environment variable: ACADSERVER="@PC-HYLITE"
License server service name: ad_elmd
License server port address default: 1422
License server port address: none
Vendor ID: ZZZZZZZ
Hostcode: ZZZZ= 0x600 = ETHER+HISECURE (ZZZ's have been edited)
Here is a sample of the log which gets recorded (ADLM.log)
01-May-21 12:50:44: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
01-May-21 12:50:54: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
01-May-21 12:51:04: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
01-May-21 12:51:14: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
01-May-21 12:51:24: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
01-May-21 12:51:33: mxm@MADMAX [0]: Packet from XXX.YYY.5.220 (Remote).
(IP edited out)
01-May-21 12:51:33: mxm@MADMAX [0]: pc-hylite lastping=990165773 (UP).
01-May-21 12:51:33: mxm@MADMAX [0]: RECV #47 RQ w.
01-May-21 12:51:33: mxm@MADMAX [0]: Keydir set to .
01-May-21 12:51:33: mxm@MADMAX [0]: No keydir sent with WHERERU packet.
01-May-21 12:51:33: mxm@MADMAX [0]: SEND #47 RP w SAR L 0 TL 0.
01-May-21 12:51:33: mxm@MADMAX [0]: -------------- LISTEN --------------.
01-May-21 12:51:33: mxm@MADMAX [0]: bury_zombies: Too soon for next cleanup.
(IP edited)
01-May-21 12:51:33: mxm@MADMAX [0]: RECV #48 RQ I.
01-May-21 12:51:33: mxm@MADMAX [0]: Process INIT.
01-May-21 12:51:33: mxm@MADMAX [0]: DO_VALIDATE: AOK.
01-May-21 12:51:33: mxm@MADMAX [0]: DO_INIT: pid=1112/XXX.YYY.5.220/5. (IP
edited)
01-May-21 12:51:33: mxm@MADMAX [0]: NEW_CLIENT finds free CID 1.
01-May-21 12:51:33: mxm@MADMAX [1]: Keydir set to .
01-May-21 12:51:33: mxm@MADMAX [1]: Connected, pid=1112/XXX.YYY.5.220/5.
01-May-21 12:51:33: mxm@MADMAX [1]: SEND #48 RP K.
Any help in sorting this out would be appreciated, thanks.
I've tried moving the license manager from D drive to C drive to no avail
(suggested in a knowledge base article). Another article showed an
intermittent problem with a similar error which said to download a new dll
but was only for win 2000. I've had support helping me so far (for a short
time) to no avail. I've reinstalled several times.
Max
7 REPLIES 7
Message 2 of 8
When you first ran the AdLM please ensure you manually launched it from
Control Panel
Try using ACADSERVER with the @ symbol i.e ACADSERVER=@PC-HYLITE
If this fails to work also try increasing the Zombie Timeout period from
Control Panel>AdLM>Settings.
Simon Gillis
Analyst
DPG Product Support EMEA
Autodesk WW Support & Services
"Max" wrote in message
news:78987A24DC1269F4B915EED182E867A2@in.WebX.maYIadrTaRb...
> Hello,
Workstation
> it.
> installed.
machine.
workstation
> following error:
lowercase
> Servers
> pc-hylite Active
> Clients
> Server PC-HYLITE:
> Environment
> Host: MADMAX
> Vendor ID: ZZZZZZZ
cleanup.
cleanup.
cleanup.
cleanup.
cleanup.
> (IP edited out)
cleanup.
> (IP edited)
cleanup.
(IP
> edited)
> Regards,
> Max
Message 3 of 8
matzmann
I've got the same problem as Max over here (messages in the log are quite identical).
But using the @keyserver environment variable and increasing the zombie timeout didn't help. What's the point in this licensing (EDITED) anyway. You pay loads of money and then your busy days and days to get it up and running. Thanks and greets
Matthias
Message 4 of 8
Thankyou for the reply.
I already had the @ in fornt of my ACADSERVER
variable on the client as I indicated in my earlier post.
The thing about the zombie timeout legth doesn't
make any sense to me. It is set to about 2 minutes. Increasing that time seems
pointless. The message says too early for zombie cleanup meaning increasing the
length will have no effect.
AN my understanding is a zombie is a license which
isn't responding on a client, I don't have a license validating on the client as
ayet.
Anyway, support came in and when he found out the
license server was not a WINDOWS NT server he left believing that was the
problem. He has since suggested I try the ACAD variable with the IP address in
the ACADSERVER. He didn't answer whether  NOT being a SERVER was the
problem.
In the adlm.log I noticed the following error which
may well be the crux of the problem
(The message log has been overwritten so I'll
explain what it said:)
It basically said that it was looking for FEATURE
150 on the server and it wasn't found. The license query tool shows that it does
however have feature 172.
I'm lead to believe that 150 is AutoCad and 172 is
autocad Map 2000. Confirmation please.
So does anyone have any leads on this piece of
information?
Max
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
identical).
Matthias
Message 5 of 8
matzmann
Hi Max,
your perfectly right. The thing about timeout doesn't make any sense at all (and you had the @ already). So how would you rate the quality of the support? 🙂
I also got it running on a NT4.0 Workstation. Did you reinstall on NT server and did it solve the problem?
As a novice to AutoCAD at first I thought you had to have AutoCAD AND AutoCADMap installed (i.e. Map is just an extension), but my predecessor told me to install only AutoCADMap - that would suffice.
So what?
Feature 172 is Map indeed, and probably 150 is AutoCAD. That would suggest that you have to install both.
Greets
Matthias
Message 6 of 8
Ok reading through your postings with a little more
time I see that you did state you already had the @ sign and I apologise for
missing it. At the start of your posting I picked up on the following statement
and jumped in too quick:-
...The ACADSERVER variable is set on the
license server: ACADSERVER="PC-HYLITE"....
As for increasing the zombie timeout period this is
known to solve some issues similar to this, especially where the network
communications may be poor due to high traffic.
Discarding all of this you do indeed require both a
feature code for AutoCAD 2000 and a feature code for MAP 4. You should have been
provided with Authorisation to give you a 150 feature key and a 172 feature key.
This licensing method changed with the 2000i based vertical products that only
require the product specific feature and not AutoCAD as well.
Simon Gillis
Analyst
DPG Product
Support EMEA
Hi
Max,
So what?
Greets
Matthias
Message 7 of 8
matzmann
Yes! That's it!
Finally we got it running.
Thanks to AutoDesk support this time.
Greets
Matthias
Message 8 of 8
Thank you Simon
 If only the support who gave us the license
had indicated both authorisations were required we would have saved 3 weeks of
turmoil.
 Local support also never asked if we had
installed both authorisations when attempting to resolve the issue.
Regards and many thanks,
Max
more time I see that you did state you already had the @ sign and I apologise
for missing it. At the start of your posting I picked up on the following
statement and jumped in too quick:-
is known to solve some issues similar to this, especially where the network
a feature code for AutoCAD 2000 and a feature code for MAP 4. You should have
been provided with Authorisation to give you a 150 feature key and a 172
feature key. This licensing method changed with the 2000i based vertical
products that only require the product specific feature and not AutoCAD as
well.
Simon Gillis
Analyst
DPG Product
Support EMEA
Hi
Max,
support? 🙂
So what?
Greets
Matthias
Administrator Productivity
