I'm using network license for all Autodesk produck. I wanted to test the Autodesk Fabrication, but whaen I install it as standalone it says I have a license problem. When I try to install as a network then the serial doesn't work. Any solution that doesn't require setting up a whole new computer to do just that?
Solved by DarrenP. Go to Solution.
DarrenP
you can have your reseller try to get one from autodesk
DarrenP
yea
DarrenP
