Installation & Licensing
New Member
sansu94
Message 1 of 7 (2,014 Views)
Network error
2014 Views, 6 Replies
02-05-2013 07:40 PM
Im a student when i tried to download Autodesk Maya 2013 Install Now method it show Network error but my network is good  what i should do im running Window 8 32bit
philip.s
Message 2 of 7 (1,994 Views)
Re: Network error
02-06-2013 11:54 AM in reply to: sansu94
Hello SanK,
The easiest workaround in this case would be to download the software via one of the alternative methods, either Browser Download or Download Now.
Philip Schmelzer
New Member
grantdesk
Message 3 of 7 (1,929 Views)
Re: Network error
04-01-2013 02:30 AM in reply to: philip.s
Both are not available for Autocad 2014.
New Member
kvillasenor
Message 4 of 7 (1,551 Views)
Re: Network error
09-24-2013 06:54 PM in reply to: philip.s
I am also experiencing the same problem but with Revit 2014 32-64bit. I've tried all the methods I can to install Revit 2014, even turning off my firewall didnt help. I've even gone as far as uninstalling the old Revit 2013 software and any other software associated with the autodesk, and still nothing. Some of the other students at the school I attend are also experiencing the same problem :smileysad:
Any suggestions?
Product Support
asburyj
Message 5 of 7 (1,529 Views)
Re: Network error
09-25-2013 09:03 AM in reply to: kvillasenor
I would suggest trying to download the software from the virtual agent as a workaround.
The steps are as follows:
1.     Go to http://www.autodesk.com
2.     At the bottom of the page, beneath "Help and Support" click "Customer Service"
3.     Click the "Ask" button for the "Virtual Agent"
4.     Once the Virtual Agent opens, click "Downloading and Installation"
5.     Click "Software Download links"
6.     Click "I need to redownload my product"
7.     Select the appropriate product and download
Jeffry Asbury
New Member
CERANU
Message 6 of 7 (416 Views)
Re: Network error
07-31-2014 08:01 PM in reply to: sansu94
I'm having the exact same problem with Maya 2014 on a PC with Windows 8. So far I've tried with both Install Now and Download Now options and none of them work.
Product Support
asburyj
Message 7 of 7 (400 Views)
Re: Network error
08-01-2014 08:05 AM in reply to: CERANU
Hi Ceranu,
If those methods aren't working for you I would suggest using the browser download method or the direct download links on the virtual agent.
Go to http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Select the 2nd Choice "Download Links "
Select your product
You are now presented with the choice to download your software.
Jeffry Asbury
