Hello. im trying to install maya 2015 student version and it refuses to download, i have used all 3 install options but 2 say "Network error" and exit out, i tried the browser download and it tells me "one or more files have not been installed properly" so i have reinstalled it at least 3 times and none of the methods have worked at all. It still gives me the same problems can anyone help me on this please? It is very frustrating to say the least...
Solved by Dank123. Go to Solution.
Solved by jessica.t. Go to Solution.
Hi @Dank123 and welcome to the Autodesk Community!
Apologies for the frustration but we'll get this figured out! Before your next download attempt, please take these steps:
If the problem persists after this, please reply to this post with further details. Or please "Accept as a Solution" if this post resolves your issue so that others with this same question can more easily find an answer. Thank you!
Hi thanks for your help but I think that my system is not compatible with Maya 2015 its very old now. That may be the problem as I did everything you suggested and I had the same error. Maya 2012 installs and works just fine which was the previous version I was using.
If anyone needs help with this problem i suggest they look at the system requirements first and then try the above method.
