I am trying to install the 2015 version of 3Ds Max for students, but when it gets to nearly the end it says "Network Error, cannot download. Check connections and try again." My internet connection is just fine as I can still browse. I have tried turning off my protection and firewall in fear that it may be blocking it yet no luck. Any idea what might be causing this?
Solved by jessica.t. Go to Solution.
Im receiving the same issues as everyone else and i have done everything it says on this link http://knowledge.autodesk.com/contactus#when
I recieve this pop everytime, and i know for a fact that it has nothing to do with my connection either.
Really eager to know how to fix it, thanks!
@Anonymous
You are welcome. Great to hear it made sense to you And thank you for sharing this with other community members! Please let us know if you have any other questions.
Hi @Anonymous
Welcome to Autodesk Community!
Have you tried an alternate method of download? Such as the "Download Now" or "Browser Download", or from the Virtual Agent.
Let us know if that works for you.
@Anonymous You need to download both part 1 and 2. Upon completion, please save all the files in one folder before you run the installation. Let us know if you still need help!
@Anonymous What's the other pop up the comes up? Can you provide the errror message or a screenshot?
Hi @Anonymous
Please, make sure your firewall and anti-virus programs are completely turned off before downloading the software from our Virtual Agent.
I hope this helps!
@Anonymous
Thank you for the links. Unfortunately, they both link just to the main Contact Us page.
Could you please confirm that you've tried the download with both the firewall and anti-virus completely disabled?
Thank you,
Hi @Anonymous and welcome to the Autodesk Community!
Did you try the solution posted by lrundblad on the post just above yours? If not, could you please try and let us know if that solves the issue for you?
Thank you,
Hello -- I have been trying to download Revit 2015 using Firefox and have been getting the "Network Error" screen so I'm in the middle of dowloading it via the Virtual Agent recommended in various responses on this board. I chose 64-bit and am in the midst of "Part I". I've also deleted history, cookies, etc., as advised. Fingers are crossed! Any other advice? I've been trying this for the last 2 days...
Hi @carlo.ablaza and welcome to the Autodesk Community!
Also try the following steps:
Let us know how it goes! Thanks!
