Installation & Licensing
.NET Framework Runtime 4.0 Language Pack FailedInstallation aborted, Result=1603
1 REPLY 1
fayoud
6896 Views, 1 Reply
I try to install AutoCAD Civil 3D on Windows 8 Pro activated and i have problem with frame work language 4.0 probelem
Please i need to help
Oudjhih Fayçal
1 REPLY 1
TravisNave
in reply to: fayoud
Windows 8 is not a supported OS.  Futhermore, the OS has .NET preinstalled already so for you to be able to install your program, you will have to modify your setup.ini to remove the check for .NET.
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/m-p/3352895#M84974
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
