I'm trying to install the 64 bit version of ACA 2011 on Windows 7 Professional 64 bit. It fails on the Directx9 install showing: ".NET3.5 is not installed. ACA 2011 cannot be installed without this component....."
Here's the log file entries:
2011/6/27:18:10:13 09Tarantino 09TARANTINO-C === Setup started on 09TARANTINO-C by 09Tarantino ===
2011/6/27:18:12:42 09Tarantino 09TARANTINO-C Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-1073741819
2011/6/27:18:12:54 09Tarantino 09TARANTINO-C Install FARO LS 1.1.406.58 Succeeded
2011/6/27:18:13:05 09Tarantino 09TARANTINO-C Install AutoCAD Architecture 2011 Failed Installation aborted, Result=1603
2011/6/27:18:13:08 09Tarantino 09TARANTINO-C Rollback FARO LS 1.1.406.58 Succeeded
I've searched the the knoweledge base and forums and can't find a solution. Also tried several times to install .net3.5 from msoft.
Any ides?
mjt3
Microsoft .NET 3.5 is integrated into Windows 7. Try going to “Programs and Features” and select the “Turn Windows Features on and off” link. Then turn .NET 3.5 off and turn it on again if it fails repair Windows 7.
Also run Windows Update a few times to get all of the .NET and Visual C++ updates and service packs.
