Installation & Licensing
Need To Deploy Trial Version of AutoCAD 2014
4 REPLIES 4
3058 Views, 4 Replies
Hello There,
I need to create an administrative image for a trial version of AutoCAD 2014 and having problems with the license key during the configuration.is there a way to skip this or a trial key to use?
For the moment, they are planning to use it for 30 days or until they have managed to acquire a budget for it and then users will then activate the product for themselves.
I could not find a way to do this. Someone from Autdesk enlighten me please. Thanks.
DJ
4 REPLIES 4
avto
Hi DJ, I personally have never done a trial deployment for ACAD 2014, but I think if you just type some number (e.g. 123-45678901) in the Serial number box and use ACAD 2014 default product key 001F1, you should be able to create the deployment. Regards,
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
in reply to: avto
The key that you have provided worked like a charm! I hope someone else might also use this solution. Thanks a bunch!
avto
You are very welcome DJ.
I'm glad to to know that my suggestion worked for you.
Avto Chachava
Autodesk, Inc.
which installation cmd did you use?
Tags (1)
Administrator Productivity
