We are using a Distributed Server model and will be replacing one of the servers in the pool. I need to change the ADSKFLEX_LICENSE_FILE that we have in place to point to the new server. In short, I need to replace the current variable value with a new one. The issue is that these PC's number in the hundreds and are located globally.
Does anyone know an efficient method for updating the variable on all these PC's without having to touch each one manually?
Also, will we need to update the licpath.lic on each PC or will the Environment variable override this?
Mike
There is no script written specifically for this purpose.
It would be easy to modify any Environment variable modification script you can find online to do this..
eg:-
http://www.factorypattern.com/using-vbs-to-set-the-environment-variables/
Environment variable should take precedence over licapth.lic
