Installation & Licensing
kim.hoejin
190 Views, 1 Reply
need help
Hi I am a student and downloaded autocad 2013 trial and autocad mecanical 2012 of student version
there are several problems for installation
<autocad 2013>
1. The white screen is appeared when I launched CAD
2. after 30 day, I want to activate it, but nothing appeared.
<autocad mechanical 2012>
3.when extracting 2012, at the end of the extraction, error massage is appeared.
here is attached file for understanding. thanks
1 REPLY 1
TravisNave
in reply to: kim.hoejin
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
