I am trying to manage 9 ADT 2007 and 10 Revit 9.1 seats on a network.
The FlexLM version is 10.8.00 build 18869
The server name and MAC ID ihe license files that Autodesk sent are correct.
I have not combined the license files yet as I wanted to test the license manager to see if it will work with just the ADT, then I will combine the ADT and Revit licenses.
The paths to the lmgrd, lic file, and debug.log file are all correct on the config tab. I used the browse buttons to path them.
I stopped the server, started the server, waited a few minutes and reread the ADT 2007 license file and I get reread server failed.
Here is the error I get in the status readout.
Status
Flexible License Manager status on Wed 10/4/2006 12:08
[Detecting lmgrd processes...]
Error getting status: Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below. Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Filename: D:\Program Files\Autodesk Revit Building 9\Program
License path: D:\Program Files\Autodesk Revit Building 9\Program
FLEXnet Licensing error:-1,359. System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
The filename and license path are not correct in the error message. The paths to the three files are:
D:\Program Files\Autodesk Network License manager\lmgrd.exe
D:\Program Files\Autodesk Network License Manager\License\acadrevit.lic
D:\Program Files\Autodesk Network License Manager\debug.log
I will combine the Revit license with the ADT license after I geta working license manager.
Anybody that can help would be greatly appreciated.
Daryl
Message was edited by: Discussion Admin
