hi from Finland
Realy need some help, i try to install my LT2011 to my laptop but can not, did get these mesages:
Connect now and activate! (Recommended) and get this: The serial number you entered is not valid. Try again. (1),
and if i try that another way: I have an activation code from Autodesk: get this Registration-Activation Error (0015.111)
...what i can do????!!!!
I am facing the same exact issue at the moment.
Could someone with knowledge of licensing issues please respond.
Also from Finland.
Thank you.
Hello @Anonymous and @Anonymous
For direct activation and licensing assistance, please contact our License Assistance team by clicking on this link and then following the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
Hi, I did as you suggested and I filled the details of the problem and I also added few pictures of the installation/problem.
look forward to urgent assistance, thank you.
Regards
Ari L.
