My new order only included the serial number and product key code for 2015 autocad version. I cannot run 2015 on my computer, it does not meet the basic system requirements. I can only run 2014. The serial number does not work when I try to use it and the product key code for 2014. I need to get the 2014 serial number ASAP!!!
Hi Cynthia,
I have emailed you the Serial Number for your AutoCAD 2014. You should also be seeing this Serial Number when you log into your Autodesk account.
I received the email, but when trying to activate the following screen
shows. The product key code is not the one you provided and it does not
give me the option to change.
Product License Activation Options
Product: *Autodesk AutoCAD 2014* Serial Number: *XXX-XXXXXXXX* Product
Key: *001F1* Request code: *XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX*
To activate your Autodesk AutoCAD 2014 license immediately, please select
"Connect now and activate!” again. If you still experience problems during
activation, and if you requested and received an activation code from
Autodesk, select "I have an activation code from Autodesk".
Connect with Autodesk and immediately activate your product license
(requires an Internet connection)
Type the activation code that you requested and received from Autodesk.
To simplify this step, paste your entire activation code in the first box.
The remaining boxes are automatically filled.
Connect now and activate! (Recommended)
*1* *2* *3* *4* *5* *6* *7* *8* *9* *10* *11* *12* *13* *14* *15*
*16*
You can also request an activation code by visiting:
https://register.autodesk.com
*Connecting * *. . . . . . *
Hi cdverenski ,
Welcome to the Community!
The serial number you provided is Autodesk AutoCAD 2015 not AutoCAD 2014. If you want to activate the product with the serial number, please download and install the Autodesk AutoCAD 2015 with the serial number you provided and product key 001G1, then you could activate it online. You also could download the product from the Virtual Agent .
Tips: For the protection of the information, please do not post your Serial Number, request code or other privacy information in the public forum. I will help to hide it.
Hi Asad,
I edited your post and removed your email address, moving forward please do not post any personal details or License details for Security and privacy reasons.
I sent you your Serial Number for Autodesk AutoCAD 2014 via Private Message (small envelope beside your profile name).
hi pls help me i need a serial number for autocad 2014 with key of 001f1 my email bogsche28@gmail.com
Hi bogsche28, welcome to the Autodesk Community!
Do you have a student version of AutoCAD or is it a commercial version?
Thank you,
Hi @bogsche28,
I tried researching your email address in our system but there were no serial numbers associated to you. For further information please contact our Activation and Registration team:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance.
If you have any other questions please respond to this post. Thank you!
Hi @bogsche28,
Completely understood but the Activation and Registration team will be able to confirm your serial number and verify what exactly is causing the error. Please let me know if I can answer any further questions. Thank you!
Hi Jessica,
Can I also formally request for a serial number? My product license has been expired. I know it isn't legit. Kindly please help me regarding this concern. Thanks.
This posting is 3 years old. For the future don't reply to to these old posting and instead create your own.
If your serial # has expired what are you expecting?
What product and version are we talking about?
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi @marklouieavena,
As mentioned by @Mark.Lancaster, the original post in this thread is 3-years old. The 2014 release is no longer available.
If you are a Student, you can obtain a serial number and downloads for the 2015, 2016, 2017 and 2018 versions on Education Community.
If you need the software for business purposes, you can subscribe to the latest version (2018) on our Online Store or through an Authorized Reseller, then request the use of previous versions (2015, 2016 and 2017).
Hey, my name is James I'm looking for someone that has the AuotoCAD 2014 serial number that I need.
It's not supported, if you have a valid license, it'll be in your account manager. If you don't then you'd need to upgrade to the newer versions.
Also, for 2014, you'd need Windows 7 or older ... W10 / W11 will have C++ / .NET issues.
no here is going to have your serial number
contact your reseller to have them look up your info
DarrenP
