Installation & Licensing
Navisworks Manage and Freedom
7 REPLIES 7
Message 1 of 8
mdhutchinson
610 Views, 7 Replies
For 2014, can't you not any longer combine Navisworks Manage and Navisworks Freedom into a single deployment?  It doesn/t show up when the deployment is being setup. ????
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: mdhutchinson
it shows up here
see attached
DarrenP
Message 3 of 8
TravisNave
in reply to: DarrenP
Agreed.  I was going to mention the same as Darren.  What are you seeing?  Did you not get the full package?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 4 of 8
mdhutchinson
I was hoping to install Freedom from Building Designer Suite Ultimate media and combine it with Navisworks Manage and Inventor. It doesn't show up on the Ultimate media.
Message 5 of 8
DarrenP
@mdhutchinson wrote:
I was hoping to install Freedom from Building Designer Suite Ultimate media and combine it with Navisworks Manage and Inverntor. It doesn't show up on the Ultimate media.
it doesn't show up on mine either
DarrenP
Message 6 of 8
mdhutchinson
Do you suppose I could just find / download the exe or msi file and do 'Include additional software' option?
Message 7 of 8
DarrenP
no clue
never used that option
thats a new feature in 2014 deployments
i guess its possible
DarrenP
Message 8 of 8
asburyj
I'm afraid you will need to create an additional deployment for navisworks freedom  as it is not included with the building design suite installer.
You can download the Freedom installer from the below site
http://www.autodesk.com/products/autodesk-navisworks-family/autodesk-navisworks-freedom
The include additional software option in the deployment will not help in this case because the navisworks freedom installer is not a self contained install executable or msi file.
Jeffry Asbury
Administrator Productivity
