Installation & Licensing
Navisworks freedom 2013 install error
4 REPLIES 4
ITService291
1870 Views, 4 Replies
I create a deployment for Navisworks freedom 2013 and it works on some pc's without any problem. However on other pc's the installation starts but ends with a strange error.(see attachment).
4 REPLIES 4
TravisNave
in reply to: ITService291
Make sure your Windows Installer is up-to-date, local admin rights, and the real-time anti-virus is disabled.  Being seeing this error a lot with Trend Micro.  Also, make sure you're not trying to deploy a 64-bit to a 32-bit machine.
Autodesk Forums:
ITService291
All Windows are Windows 7 64bit, we use WSUS to patch all windows systems, users are local admin and we use Trendmicro as antivirus software
emily.xu
Try to install under the diagnostic mode.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
samstewart46
in reply to: emily.xu
It's probably Trend Micro I've had the same issue with Autocad and now having it installing Navisworks
Administrator Productivity
