I just installed the current Navisworks export utility plugin for 2011 products, and as soon as the installation completed I could no longer open Revit Architecture 2011. I was not working in Revit while installing the plugin. Any ideas?
I have since uninstalled the plugin but can still not open RAC. I have uninstalled and reinstalled RAC but still no luck. What the hell happened?
Thanks.
- Alex
Hi Alex,
The Navisworks support technicians gave me a couple of ideas on this.
First is to rename the CascadeInfo.cas file to something like CascadeInfo.bak then restart the application. You will find the CascadeInfo.cas file here:
Windows 7 or Vista:
C:\ProgramData\Autodesk\Adlm\
Windows XP:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm\
You may have a corrupt Revit.ini file. Rename this file the same way. Revit will recreate it. You will fint the Revit.ini file here:
C:\Program Files\Autodesk Revit Architecture 2011\Program\
