Anyone know if you need NW 2013 SP1 installed before installing SP2, or does SP2 contain SP1 fixes as well?
There is no mention of SP1 at all in the SP2 readme file.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20458011&linkID=10382102
Solved by dembkod. Go to Solution.
Mike,
Hello. The Navisworks Service Pack 2 does not require you to have the prior SP installed. Usually our installers would warn you during installation if there were missing requisites. In this case, you do not need SP1.
Thank you for taking part in our community!
Thank you,
David Dembkoski
Product Support Specialist
Autodesk Product Support
Thanks for verifying this.
It would be nice if the read me contained this info.
Cheers
