My company just installed a new server and unfortunately used a different server name for it. We have installed the network license manager on the new server but what I do not know how to do is to tell the NAVIS installations how to look to the license manager on the new server. I have so far had to leave our old server running in order to use NAVIS and will have to continue until I figure this out.
I am hoppeful that I do not have to uninstall and reinstall all of the network installations of NAVIS.
Any help would be greatly appreciated.
Solved by ukdxb012. Go to Solution.
Solved by DarrenP. Go to Solution.
you can use this: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-se...
DarrenP
Darren,
Thank you for a quick response.
I will give this a try. I guess the only way to test it is to take our old server out of service and see if I can access my licenses thru the license manager on the new server.
I assume that this will overwrite the path to the old server that was used during the original install?
Thanks so much for your help.
Bob
