Installation & Licensing
extrachannel18
208 Views, 1 Reply
My setup goes on failing
Hello people,
I go on having problems installing my AutoCAD copy
It fails when it tries to install .NET Framework 3.5 SP1 saying that I am not connected to internet whereas my line is 100% ok.
The fact is that I have Framework 4 and so I don't need this file either
Is there a way to skip the installation of this file?
Moreover, I uninstalled my Framework 4 to see if the setup could go on. Nothing changed. I keep on getting 'Error 1603'
Can somebody help me?
1 REPLY 1
TravisNave
in reply to: extrachannel18
Yes, you can skip it if you modify your setup.ini file.  I have some information on that in my link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Autodesk Forums:
Administrator Productivity
