I have a llicenses for bith Building Suite and Product Suite. I typically run these on two different computers but sometimes want to transfer the license of one product to the other machine (I have both suites loaded on both machines). However, I would like to be able to run basic autocad on both machines at all times. Unless I Iinstall two versions of autocad on both machines each with it's own license I loose the use of autocad whne I transfer the license. Is there a way of telling one installation to use either legitimate license?
Hi wchorley,
If by statement below, you meant to use a 1 seat License on 2 machines at the same time note that 1 seat of License can be installed on 2 machines but should be used one at a time.
For multiple seats Licenses, it can be installed on multiple machines and you need different Activation Codes for that.
Do reply back with more details if I seem to have misunderstood your issue or you need further clarification.
no you can't
the product keys will be different which you can not change after installation
DarrenP
