I recently installed Mudbox/3dsMax and Maya (2015 versions) on my C: Drive. User-error on my part ended up permanently deleting some of the key files for the products, whenever I try to reinstall Mudbox 2015 using the "Autodesk_MBX_2014_English_French_German_Japanese_Win_64bit_wi_en-US_Setup"
It'll just say that it's already installed and won't allow me to repair or reinstall. I do not have the Mudbox Uninstaller/Repair tool as it was one of the files I deleted.
Are there any registry keys I should delete, or is there a tool to download?
Solved by thoradalv. Go to Solution.
hello, I seem to be having the same problem but I couldn't fix it like you did.Can you halp me? I downloaded the trial version of the product and tried for 30 days,and then I installed the free academy edition.I got the product keys and all that but when I start the installation,the NEXT portion is grayed out and it says INSTALLED.I tried to delete everthing about mudbox but still,I cannot install it.Can you give me any specifics?
