Hello, i have been trying to instal Mudbox 2012 Win 32-bit. Durring installation the installer will close near half way into the first phase and the instal will fail. The installation log file says a file is in use or something like that. I have tried installing in diagnotics mode, but the same thing happened.
I have attached the installation log file.
edit* I could not get the .txt file to attach correctly. So I will just type in the last part of the log file.
Any help would be greatly appreciated. Thank you.
The installation log file said
2011/7/26:17:11:14 HP_Administrator PEPPER === Setup started on PEPPER by HP_Administrator ===
2011/7/26:17:11:14 HP_Administrator PEPPER Launch
2011/7/26:17:12:20 HP_Administrator PEPPER PageOpen LaunchDialog
2011/7/26:17:13:33 HP_Administrator PEPPER PageOpen LicenseDialog
2011/7/26:17:13:42 HP_Administrator PEPPER PageOpen ProductInfoDialog
2011/7/26:17:13:59 HP_Administrator PEPPER PageOpen ProductSelectionDialog2
2011/7/26:17:14:08 HP_Administrator PEPPER PageOpen FullProgressDialog
2011/7/26:17:14:09 HP_Administrator PEPPER Installing Autodesk® Mudbox™ 2012: TRANSFORMS="C:\Autodesk\Mudbox_2012_EFGJ_Win_32-bit\x86\en-us\Mudbox\Mudbox2012.0.mst;C:\DOCUME~1\HP_ADM~1\LOCALS~1\Temp\_AI1E.tmp\x86\Mudbox\Mudbox2012.0-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Mudbox_2012_EFGJ_Win_32-bit\" INSTALLDIR="C:\Program Files\Autodesk\Mudbox 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2011/7/26:17:14:42 HP_Administrator PEPPER Install Autodesk® Mudbox™ 2012 Failed Installation aborted, Result=1601
Solved by todd.kane. Go to Solution.
Hello there:
You may have issues with your Windows Installer. Check out this MS Article and see if it helps:
http://support.microsoft.com/kb/315353
What os did you use ?
Have you try windowsupdate before installation ?
Try :
1- msiexec /unreg
2- msiexec /regserver
That fixed it. Thank you both for the reply. Now I just have to figure out how I messed up my Windows Installer so I don't do it again.
I cannot install Mudbox. I am trying to download the free trial to try it out, but I keep getting the same error message over and over over and over again...regardless of where I try to save it. The message is "try again in a new location"
WHERE am I supposed to try and save this? I have tried making a folder, tried saving it to an existing folder, tried saving it to desktop...WHERE do I save it?
