Hello, I have this problem, but I don't understand why. I'm student and I registered in order to be. I tried to download and instal Maya. What should I do for getting a free 3-year license?
Solved by JDMather. Go to Solution.
Have you already Downloaded Maya?? Which version are you trying to download?
I haven't. I tried with all versions. I have option to download/install Maya, but it will be trial. I need student version.
@Pajce91! wrote:
.....but it will be trial. I need student version.
All Autodesk software initially installs in trial mode. Simply install and run in trial mode, keep checking over the next 30days for your serial number to be assigned on the student community and when it is assigned simply click Activate rather than Run as Trial when you start the software that day.
If it get close to the end of the 30-day trial and your student license serial number has still not been assigned, then I would get worried and post back.
Hi, I am having the same problem. When I downloaded the trial of AutoCAD and requested a student license, I got the message:
Now the trial is over and I still get the same message, and am not able to use the software. How can I get a serial number?
Thanks, Alex.
Screenshots attached.
Has anyone managed to fix it yet? I've got the same problem and I've waited until after the 30 day trial period and they still didn't give me the code
I had this problem and what I did was use another explorer, for example use internet explorer go to autodesk and sing in with your user then select the software, version and language.
