Installation & Licensing
Moving Network License Manager to different server
2 REPLIES 2
1320 Views, 2 Replies
We are currently using the FLEXlm network license manager for AutoCAD 2005.  We need to move the FLEXlm to a different server due to the obsolesence of the old server.  Our subscription service is expired, but we kept it through the AutoCAD 2009 release.  We never upgraded to AutoCAD 2009.
My questions are:
1) Can we move the FLEXlm to a different server and still receive a new AutoCAD 2005 authorization/lic file, even though our subscription has expired?
2) If we upgrade to AutoCAD 2009, can we then move the FLEXlm to a new server?
Thanks.
2 REPLIES 2
DarrenP
you have to generate a new license file for the new server
you need your serial number. server name, mac address
DarrenP
TravisNave
You will probably only be able to get a LIC file for your last available version, unless you can get an exception from Autodesk. You might consider upgrading to 2012 on Subscription so you don't have this problem in the future. Otherwise, you can keep that server on life support specifically to be your NLM server. Good luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
