Ditto! Directions at http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9626479&linkID=9240617.
worked perfectly with AutoCad 2010 in a Win XP 32bit installation. However, on the same computer, Rhino is unable to find the the new Flex server after the addition of the system "Environment Variable" of the licnese server.
Any ideas?
You can try a couple of things for the Rhino change. Since it uses a different vendor, try one of these environment variables:
LM_LICENSE_FILE
-or-
VENDOR_LICENSE_FILE
You will need to replace the vendor keyword with the name of the vendor daemon that Rhino uses to connect to the NLM. For example, Autodesk uses ADSKFLEX. So whatever the vendor .exe file is for Rhino, use that as your @SERVERNAME variable.
