Installation & Licensing
1825 Views, 2 Replies
Moving C drive files
I just installed Revit Arch. 2013 on a drive other than C. My C drive is nearing capacity and I would like to make some more space. It still installed files in my C drive under ProgramData\Autodesk that include subfolders shown in the attached picture. Is it possible to move these over to another drive?
2 REPLIES 2
DannyHubbard
Check out the following post, should help you out.
http://forums.autodesk.com/t5/Installation-Licensing/Can-t-Install-on-a-non-bootable-Hard-drive/m-p/...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
TravisNave
You can probably free a lot of space on C:\ by moving your %TEMP% location, your paging swap file, and disabling your hibernation file.  I suspect that would free up close to 10GB of space alone.  Reducing your browser cache along with some other basic cleanup can free up tons of space.
Autodesk Forums:
Administrator Productivity
