DarrenP
BTW, the latest version on the 2011 media is 11.7 if you have and want to install that version.
Hello everyone,
Just wondering if someone can help me, when I move Network License Manager to new Server. I've got a wrong IP ADDRESS in the LMTOOLS not the correct IP on my server. I have a new autodesk license , configured the Server NAME and SERVER ID. So when I open the license file, i can see the correct SERVER HOST NAME and SERVER ID.
However, when i was configured the LMTOOLS on my server, for some reason I am getting a wrong IP ADDRESS e.g. 169.254.170.21 and this is not the correct IP on my server. I have tried uninstall/reinstall same thing happen. So now all clients machine autodesk is not working! not really sure what mistakes I've done.
Any advise greatly appriciated.
Thank you so much!
If your server is getting a 169. address then it is not getting a proper network connection or an IP from the DHCP server. Futhermore, your NLM server should not be set for automatic IP address anyway. You should always set a static IP address on your server to prevent DNS issues. So manually set your new server with the proper IP address in your subnet and then verify the connectivity from the client.
Thank you so much Travis for your advise.
So strange, My server has a static IP address I configured IP - Subnet Mask- default gateway + Preferred DNS Server.
In addition, I did LMTOOLS configuration on my OLD server works well. However since my license was expired and I now have a new Autodesk license so my plan is to install to my new server but it wasn’t successful. I'll continue to investigate this issue and hoping to find immediate solution.
Thank you so much for you time and effort.
