Installation & Licensing
Move license to new server
5 REPLIES 5
SEC_CAD
418 Views, 5 Replies
I raised a ticket (10181973) two weeks ago but no one from AutoDesk has gotten back to me.
I called AutoDesk in Melbourne about a week ago but they were unable to help, telling me that I just had to email customersupport@autodesk.com. I have been doing that but still get no response.
We have moved so I need to move my 3 network licenses to a new server.
The online tool did not recognise my serial number. I know that it is correct.
Can someone at AutoDesk please help with this case? It is now urgent.
5 REPLIES 5
TravisNave
in reply to: SEC_CAD
See my link about Invalid Serial Numbers below.  Then get it figured out with your Reseller.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-S...
Autodesk Forums:
SEC_CAD
in reply to: TravisNave
Thanks Travis. I have passed the link to our IT department and hope to get the license file that was sent by your team installed very soon.
Michael
SEC_CAD
Hi Travis, Can you help me with the next step please.
Our IT have installed the license on our server. When I open AutoCAD 2009 it seems to have found another license (We have many companies in our organisation that also use AutoCAD so this is possible). I want to ensure that my AutoCAD client is using our server license. From the Product Information screen I clicked [Update] and was able to change the serial number to my serial number. I followed the instructions here  to set the ADSKFLEX_LICENSE_FILE to point to the server where the license was installed. I restarted my PC.
When I restarted AutoCAD it still said that I had a Standalone - Locked license type.
How do I point my AutoCAD client to my license server and how do I tell when it has connected to the correct license?
Many thanks,
Michael
TravisNave
If your license was installed as a stand-alone, you need to convert it to a network license.  Since yours is 2009, you should be able to do it the easy old-fashioned way.  Rather than re-explain it, you can read about it here.
Alternately, you can reinstall as a network verison.
Good Luck!
Autodesk Forums:
SEC_CAD
Thanks again Travis, I guess I am stuck with the stand alone license that seems to be working because I don't have the AdskNetSrv.exe file required by the instrucions.
Cheers,
Michael
Administrator Productivity
