Solved by Antonio_Barroca. Go to Solution.
Hi Raffaele, Autodesk states in the solution TS1056795 Virtual server platforms and the Autodesk Network License Manager that running the Network License Manager on virtual server platforms has not been tested; therefore, it is not supported by Autodesk.
I would recommend installing the NLM in a non Virtual server.
Cheers
Antonio Barroca
The link above appears to be broken. This is the correct link to the technical solution Virtual server platforms and the Autodesk Network License Manager
