Hello everyone,
I want to get Autodesk Moldflow Insight 2015 running. Successfully installed the new License Manager, Moldflow Advisor and Communicator. Even installed Insight, but there is no program to find.
I found another setup-file in my Autodesk\Simulation Moldflow Insight 2015\Moldflow Insight\Setup - path which I started, but I get an installation error: some "ami_solver-x64d.msi" is missing.
I searched for it and there is no such file on my computer. How come this file didn´t load? Where is it supposed to be? Or could it be an error message indicating something different?
I really need to get the program running, so thanks for your help!
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
