Autodesk Moldflow licenses can be installed on any existing Autodesk FlexLM license server which uses the single or distributed server model. Autodesk Moldflow licensing does not support the redundant model.
I would recommend that you review the Autodesk License Manager Installation Guide (C:\Autodesk\Autodesk_Moldflow_2011_English\adlm2011\documents\adlm2011_igd_en.pdf for 2011) then Install and configure a license service and the ampsa proxy server on a different host than that of the three hosts in the redundant quorum.
Ampsa.exe is a proxy that is installed on the same host as the license service and that sits between the license service and the Moldflow products. Communication between the license service and this proxy is done with port 2080. Communication between the proxy and the application is done through port 6014. You can find more information on this communication by referring to the section on the Autodesk License Manager (Moldflow) server/client model in the License Manager Install guide mentioned above. This section begins on page 11 of the .pdf.
The ports for the master daemon (lmgrd.exe) are any one port in the range 27000 through 27001. In an environment where there are no other FLEXlm/net license services you would let the port be chosen automatically. If you must change this you can specify the port on the first line, after the MAC address with a space between the MAC address and port, of the license file. You can choose any one port in the range 27000 through 27009 so that it is not conflicting with another service on the same host.
Replacing the redundant model with several single servers and configuring the clients for the distributed model would be a recommended alternative.
I might have a similar problem:
Our custommer runs a license server, where they have several network licenses. One of them is for Maya 2011, which can be accessed from clients without problem. They added license for Moldflow Insight Performance (AMIP) 2011 (combined the files properly). If they perform server status query from lmtools, they have the new license for AMIP 2011 available.
The problem is that the client machine can not access the license for AMIP 2011. They tried to shut down all the firewalls, double checked server name and MAC, they even tried removing the Maya license and leave only AMPI license, but still nothing. They still get the usual screen (see attacement). The Maya 2011 license still works perfectly.
If you needed any logs or anything please let me know.
Thank you for any help.
When adding licenses for Moldflow to an existing license server the license service may need to be upgraded to 11.7 and the Moldflow Installer will need to be run to install additional components on the license server.
Are they using the 11.7 version of FLEXlm? Did they install the proxy for Moldflow licensing?
This proxy sits between the Moldflow application and the license server. See Figure 2 on Page 12 of the adlm2011_igd_en.pdf. They must use the default TCP/IP ports and make sure they are open in the firewall:
2080 – Autodesk Vendor Daemon port
6014 – Moldflow proxy port
27000 through 27009 - FLEXlm Master Daemon ports
We moved your post to a new topic.
