Installation & Licensing
Missing SBD.msi for the Product Design Suite installation
14 REPLIES 14
Message 1 of 15
YmmcAuto
2243 Views, 14 Replies
I recently downloaded Product Design Suite.  When I run setup.exe, I get this error:
" The system cannot open the device of file specified."  Then I get :
"The system cannot find the path specified
C:\Docume~1\ADMINI~1\LOCALS~1\Temp\3\_AI26.tmp\x86\SBD\SBD.msi".
I get the same type of error with the 64_bit install.
14 REPLIES 14
Message 2 of 15
TravisNave
in reply to: YmmcAuto
What version?  What OS?
Autodesk Forums:
Message 3 of 15
YmmcAuto
in reply to: TravisNave
The server is running Windows 2003 Server and I am trying to install Autodesk Product Design Suite 2013.
Message 4 of 15
TravisNave
You cannot install to the server itself.  It's neither a supported platform, nor is allowed by the EULA.  Are you trying instead to make a deployment?
Autodesk Forums:
Message 5 of 15
YmmcAuto
I apologize for the lack of clarity, but I am trying to create a deployment.  As soon and the setup file starts to initialize, I received the errors mentioned above.
Message 6 of 15
TravisNave
Ah, excellent.  Okay, well what you can try to do is create the deployment from your workstation and still path it to the UNC share on the server.  That way you can avoid this whole mess completely and still create and use your deployment exactly where you want it.
Autodesk Forums:
Message 7 of 15
YmmcAuto
When I run it on my workstation I get the same error.
Message 8 of 15
TravisNave
Well, now that is odd.  Is your download corrupt maybe?
Autodesk Forums:
Message 9 of 15
YmmcAuto
I downloaded the Product 32-bit and 64-bit separately.  I also downloaded the Factory design 2013 weeks before and all have the similar problems.  The Product Design 2013 is missing SBD.msi and Factory Design is missing inventor.msi.
Message 10 of 15
TravisNave
That's just plain odd.  Kinda makes me wonder if you have the whole package.  You don't have some anti-virus that blocks .msi files or something, do you?  Trend Micro has a habit of doing weird stuff like that.
Autodesk Forums:
Message 11 of 15
YmmcAuto
I disabled the anti-virus and then tried to run the .exe again but, I received the same error.
Message 12 of 15
TravisNave
And you are choosing to create a deployment, correct?  Also, do not add any service packs to the deployment.
Autodesk Forums:
Message 13 of 15
YmmcAuto
And we use Symanatec Endpoint Protection.
Message 14 of 15
TravisNave
Hmmm.  That makes me suspicious.  A lot of these new protection suites literally block .exe .msi .bat, etc.  I swear that Symantec handicaps a computer now more than any virus does.  Smiley Very Happy
Autodesk Forums:
Message 15 of 15
YmmcAuto
I disabled Symatec Endpoint Encryption and tried to run the executable again but  I received the same error.
Administrator Productivity
