Installation & Licensing
Tamiel
1167 Views, 4 Replies
Missing Menu buttons
When ever i click on the file/3dsmax icon button it says it can’t find ApplicationMenu.xaml then after i go past 2 error messages then when the menu opens its missing loads of options so i can’t import/export or things like that.
Iv'e tried reinstalling and checked and the .xaml files no where on my computer.
4 REPLIES 4
anil_choudhary
in reply to: Tamiel
You may want to run feature related queries  by the 3DS Max forum instead of this one.
http://area.autodesk.com/forum/autodesk-3ds-max/
Please try the tips below and let me know if they help.
Please try a quick reset of 3ds Max as per steps below.
Close 3ds Max. rename the enu folder to enu.old
-in XP
C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\<version>\enu
-in XP 64 bit
C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\3dsmax\2010 - 64bit
-in Vista/Windows  7
C:\Users\<username>\AppData\Local\Autodesk\3dsmax\<version>\enu.
 These paths include hidden folders, so be sure to enable the ability to see hidden folders in Windows.
Restart 3ds max
Cheers.
Anil Choudhary
Product Support Specialist
Autodesk, Inc.
Tamiel
in reply to: anil_choudhary
All that happens when i try that is it says C:\Program  Files\Autodesk\3ds maxv 2010\UI\MaxStartUI.mnu is invalid.
Then it says 3ds max fails to start.
Heres a link to the AREA Discussion: http://area.autodesk.com/forum/autodesk-3ds-max/autodesk-3ds-max--3ds-max-design-2010/cant-importexp...
anil_choudhary
in reply to: Tamiel
Hello Tamiel,
Did you try the above solution of reseting the preference by  renaming  or moving the enu folder to another location and restart max to create new default preferences.
OR
can you create a new user account and restart max from there and see if that works.
Pls let me know if that helps.
Cheers
Anil Choudhary
Autodesk, Inc.
Anil thanksfor the GREAT answer; IT WORKED! Smiley Wink
Administrator Productivity
