Installation & Licensing
Missing link between Robot and Revit 2013
3 REPLIES 3
SFForest
385 Views, 3 Replies
My company would like to investigate how Autodesk Robot works with Revit. I installed a trial version of Autodesk Robot 2012 but I'm not getting the Analysis & Code Check Options in Revit. Is that because it is a trial version or do I need to install something else? Thanks for your help.
Scott
3 REPLIES 3
DarrenP
in reply to: SFForest
its a separate installation you get from subscription center
DarrenP
SFForest
in reply to: DarrenP
The link between Robot 2012 works with Revit 2012 but not Revit 2013. Does the year associated with Robot need to match the Revit year? Is there a trial version of Robot 2013? Will Robot 2014 work with Revit 2013? Thanks again for the help,
Scott
DarrenP
they both have to be the same version
you can download 2013 from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Please accept as a solution if this fully resolves the issue
DarrenP
Administrator Productivity
