Installation & Licensing
Missing ccL100U.dll file?
4 REPLIES 4
284 Views, 4 Replies
I have just recently installed the student version of inventor profesional 2012 on my pc and it comes up with an error as shown in the attachment. I have tried to fix and reinstall it with no luck. any ideas?
4 REPLIES 4
TravisNave
This is a problem with Norton/Symantec system protection and anti-virus.  I would probably recommend that you uninstall this product if it is on your machine, reboot, then try again.  You should then install another anti-virus program either free from Microsoft or a 3rd party provider like AVG
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hi, Thanks for the help so far. I have done what you have listed in your post, uninstalling Norton and Inventor and also installed AVG but have run into another problem. When i go into my downloads and try to click on the installer for Inventor, Windows crashes and wont respond. Also the startup time of the computer has noticably increased, is this the doing of AVG?
I left my computer sitting for about 5 hours and it loaded, Inventor works great. Thanks for the help.
TravisNave
Unlikely. I recommended that you installed Inventor before the new
antivirus though. However AVG should not have caused any of those problems.
It's possible that your hard drive is failing. You can check your system
event logs to be sure.
Autodesk Forums:
Administrator Productivity
