Upgrading to 2015 Please help!
Attached in the Error log:
Errors
Tool Palette Files: Error encountered saving Catalog to file "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2015\R21\enu\Support\Shapes.atc".
Pgp File: Error encountered migrating acadlt.pgp file (Value cannot be null. Parameter name: path).
General Information
AutoCAD LT 2015 - English Migration Log Generated by: AutoCAD LT 2015 - English Migrate Custom Settings version 20.0.51.0 Settings migrated from: AutoCAD LT 2012 - English Migration template file: C:\Program Files\Autodesk\AutoCAD LT 2015\AdMigrator.xml version 1.0 Migration performed on: 7/22/2014 1:55:55 PM
This log details the migration of settings from a previous version of AutoCAD LT. Any problems encountered during the migration are listed in this log.
You can restore the default AutoCAD LT 2015 - English installation settings by running "Reset Settings to Default" from the Windows Start menu->Programs->Autodesk->AutoCAD LT 2015 - English->Reset Settings to Default.
AutoCAD LT 2012 - English Installation Folder = "C:\Program Files\Autodesk\AutoCAD LT 2012 - English\"
AutoCAD LT 2012 - English Local Profile Root Folder = "C:\Users\MChilson\AppData\Local\Autodesk\AutoCAD LT 2012 - English\R17\enu\"
AutoCAD LT 2012 - English Roamable Profile Root Folder = "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2012 - English\R17\enu\"
AutoCAD LT 2012 - English All Users Profile Root Folder = "C:\ProgramData\Autodesk\AutoCAD LT 2012 - English\R17\enu\"
Settings migrated to:
AutoCAD LT 2015 - English Installation Folder = "C:\Program Files\Autodesk\AutoCAD LT 2015\"
AutoCAD LT 2015 - English Local Profile Root Folder = "C:\Users\MChilson\AppData\Local\Autodesk\AutoCAD LT 2015\R21\enu\"
AutoCAD LT 2015 - English Roamable Profile Root Folder = "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2015\R21\enu\"
AutoCAD LT 2015 - English All Users Profile Root Folder = "C:\ProgramData\Autodesk\AutoCAD LT 2015\R21\enu\"
Migration Details
Migrating Profile: "<<Unnamed Profile>>"
Main CUI File set to "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2015\R21\enu\support\acadlt.cuix"
ToolPalette location migrated from "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2012 - English\R17\enu\Support" to "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2015\R21\enu\Support"
AuthorPalette location migrated from "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2012 - English\R17\enu\Support\AuthorPalette" to "C:\Users\MChilson\AppData\Roaming\Autodesk\AutoCAD LT 2015\R21\enu\Support\AuthorPalette"
0 acadlt.lin line patterns migrated from "C:\Users\MChilson\appdata\roaming\autodesk\autocad lt 2012 - english\r17\enu\support\acadlt.lin" to ""
0 acadltiso.lin line patterns migrated from "C:\Users\MChilson\appdata\roaming\autodesk\autocad lt 2012 - english\r17\enu\support\acadltiso.lin" to ""
0 acadlt.pat hatch patterns migrated from "C:\Users\MChilson\appdata\roaming\autodesk\autocad lt 2012 - english\r17\enu\support\acadlt.pat" to ""
0 acadltiso.pat hatch patterns migrated from "C:\Users\MChilson\appdata\roaming\autodesk\autocad lt 2012 - english\r17\enu\support\acadltiso.pat" to ""
Customization files perferences everything from 2012 user profile to 2015.
I have built tons of custom buttons and have a workspace and tool bars set.
I got alot of it load manually copying things from one folder to the other.
but not easy or fast!
