I am having problems migrating Autodesk Vault Collaboration 2013 to a new server. I am fairly new to Autodesk products and was told all I needed to do was login to ADMS on old server and perform a backup, install Vault on the new server and restore from backup. All my settings appear to be inplace and when I login to the web client I can see the folder structure; however, the files do not seem to be there.
The other problem is that I get Failed to acquire a license error when trying to login with the Autodesk Vault Client.
Thanks in advance for any help you can offer me.
you need to have flex lm set up with a vault collaboration license before you can log into vault from the client
DarrenP
I actually already had the flex lm installed. What I did wrong was thinking all I had to do was move license file over to. Appearently, I have to get a new license file instead of just being able to modify the current one. I have the server up and going now using the previous license server till I can get the new one. Thanks for the response.
