I would like to migrate my Autocad 2013 from standalone to network. I have change the value in the registry (HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B001\AdLM Type =1) but when I open Autocad 2013 I get an error message (see attachment)
It's in french so here is the traduction : Security system (license manager software lock) does not work or has not been installed correctly.
I know that reinstalling the software correctly would be a solution but I would like to know if there is another solution instead of reinstalling.
Thank you
Solved by DarrenP. Go to Solution.
nope that is the only solution if the registry hack doesn't work
DarrenP
