Installation & Licensing
Member
0 Kudos
Post 1 of 9
Microsoft Visual C++ 2005 Redistributable (x64) error
478 Views, 8 Replies
04-27-2014 05:00 PM
i keep getting a failed install due to Microsoft Visual C++ 2005 Redistributable (x64) i have tried all that i can think of but still nothing . can anyone help?
*Expert Elite*
1,593 Kudos
Post 2 of 9
Re: Microsoft Visual C++ 2005 Redistributable (x64) error
04-28-2014 05:46 AM in reply to: zack723
Have you tried removing all instances of VC++ from your PC, restarting your PC, running the installation, then using Windows Update to put back the VC++ versions your other software needs? Worked here recently when I had the same issue.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 3 of 9
04-28-2014 08:29 AM in reply to: pendean
Yes still the same error
Sent from my iPhone
*Expert Elite*
897 Kudos
Post 4 of 9
04-28-2014 08:33 AM in reply to: zack723
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Member
0 Kudos
Post 5 of 9
07-10-2014 06:52 PM in reply to: TravisNave
ok what is the pre req? idk what it is and i tried your tute but the dotnet4land isnt in the script
*Expert Elite*
897 Kudos
Post 6 of 9
07-11-2014 01:29 PM in reply to: zack723
It's the C++ 2005 as listed in the log file.
Member
0 Kudos
Post 7 of 9
07-11-2014 02:01 PM in reply to: TravisNave
Ok what about rewriteing the ini? The dot thingy isnt in there
Sent from my iPhone
*Expert Elite*
897 Kudos
Post 8 of 9
07-11-2014 02:09 PM in reply to: zack723
It is VCREDIST.  Different prereq.
Member
0 Kudos
Post 9 of 9
07-11-2014 02:46 PM in reply to: TravisNave
Ok ill uninstall it and see what happns
Sent from my iPhone
Post to the Community
New Post
