Where do I find a metric version of Autocad Revit for installation?
The student version I have downloaded has Imperial as the default. Thank you.
No. It does not give me that option. it is a US website. it only asks for language.
Any more ideas?
I have installed Revit 2011 and 2012 and I also did a bit of research. You need to set the Imperial/Metric via the UI.
http://forums.augi.com/showthread.php?t=136539
There is an older post about the 'default' for 2011 here:
http://usa.autodesk.com/getdoc/id=TS15220364
Thanks for the further input. I will experiment with that. How I solved it was that I re-downloaded (Revit for Archtitects 2011 for students). During the download it asked what language and I said English. When I then installed it asked what country and I said Australia and then got metric. So I am wondering if it downloads both metric and imperial and when you install it only installs according to what country you say you are from. Not sure how I ended up with Imperial the first time.
