Hi there!
I have been following this post for a while, and have been facing with similar problem of not able to find/install mental ray in 3d studio max 2017!
I even downloaded the above mental ray installer folder and tried installing it, but unfortunately I get the following message in the end:
And I noticed that NO files are copied in the installation folder after this message. Which clearly means that nothing is installed.
However, I would also like to state that when installing the MentalrayPlugin Folder (by clicking the MentalrayPlugins2017.msi file, the package gets installed fully but Mental Ray DOES NOT shows up in the render settings.
I am not sure why I am not able to install from Mentalray2017.msi file and get the above error!
I am on Windows 8 (not 8.1), could it be because of that?
I have disabled/uninstalled ALL the anti-virus, spam-ware programs.
Hope to receive some help on this!
Hello @gautam_offset,
I have moved your post to a new thread so that I&L can help you with this issue. I have also edited the title slightly for more efficient searching. Thanks for your understanding.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Try the solution posted here by @tony.su. Don't forget to update this post with your results.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
Please post any comments to the thread below, as this one will be deleted by moderator due to duplicate entries...
Ongoing Thread:
Darin Green
I just wanted to follow up here, any progress on this issue?
Best Regards,
