Hi
So I am using a student version of Maya 2015 and I cannot use the Mental_Ray plug-in, I have tried reinstalling Maya-2015, download service packs sp2/3/4/5, downloading the Standalone and Satellite, moving the Mayatomir file into the Maya 2015 plug-in folder, nothing works. I have checked the forums and tried the solutions but nothing works at all. What could be the problem or how could I fix it?
Solved by david.lau. Go to Solution.
Can you reset your preferences in Maya? An example path is C:\Users\USERNAME\Documents\maya\2015-x64\prefs
Just rename the 'prefs' to 'prefs-old'.
Hi, thanks for your reply.
No this has not worked, the same "Error 1, the specified procedure could not be found" still occurs. Is it possible that the file is just not in the right directory?
