Hello i keep getting errors when i try and load a new install of Maya 2013. I have removed it twice and reinstalled still same issue.
here is the error:
// Error: file: C:/Program Files/Autodesk/Maya2013/scripts/startup/HotboxMenus.mel line 157: //
// mental ray for Maya 2013
// Mental ray for Maya: using startup file C:/Program Files/Autodesk/Maya2013/mentalray//maya.rayrc.
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: C:/Program Files/Autodesk/Maya2013/mentalray//maya.rayrc
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/abcimport.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/abcimport.dll
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/AdskShaderSDKWrappers.mi
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/architectural.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/architectural.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/base.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/base.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/builtin_bsdf.mi
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/contour.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/contour.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/paint.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/paint.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/physics.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/physics.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/production.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/production.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/ptex.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/ptex.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/subsurface.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/subsurface.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/surfaceSampler.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/surfaceSampler.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/userdata.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/userdata.dll
// parsing C:/Program Files/Autodesk/Maya2013/mentalray/shaders/include/useribl.mi
// loading C:/Program Files/Autodesk/Maya2013/mentalray/shaders/useribl.dll
// AbcExport v1.0 using Alembic 1.0.4 (built Jan 16 2012 14:33:10)
// AbcImport v1.0 using Alembic 1.0.4 (built Jan 16 2012 14:33:10)
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/Maya2013/mentalray/scripts/mentalrayUI.mel line 1607: menu: Object 'mainRenderMenu' not found. //
updateRendererUI;
I am getting the exact same error. I have reinstalled the program and still get the same error. What can be done about this?
John R. Torres
