I have both MAX and Maya on subscription, but as of the 2013 release I am only able to install one of the programs at a time.
I can get either Max 2013 or Maya 2013 to work on my computer, but only if I erase all versions of all Autodesk products beforehand and manually delete the "ProductInformation.pit" file located in "C:\ProgramData\Autodesk\AdLM" between installations.
Worse, since installing Max 2013 I'm no longer able to re-install Max 2012, as it keeps hanging on the Material Library installation. Very frustrating as it means I have now lost access to some of my most used plug-ins such as Vray (until the 2013 patch comes out).
Currently I have MAX 2013 installed, as that is the program I use most, but now have no access at all to any version of Maya.
If I try to install Maya 2013, it installs the DirectX portion, then on the main Maya installation it quits with the following log file :
2012/4/15:12:03:49 Mark MARK-COSMOS === Setup started on MARK-COSMOS by Mark ===
2012/4/15:12:03:49 Mark MARK-COSMOS Launch
2012/4/15:12:03:52 Mark MARK-COSMOS PageOpen LaunchDialog
2012/4/15:12:03:53 Mark MARK-COSMOS PageOpen LicenseDialog
2012/4/15:12:03:56 Mark MARK-COSMOS PageOpen ProductInfoDialog
2012/4/15:12:05:33 Mark MARK-COSMOS PageOpen ProductSelectionDialog2
2012/4/15:12:11:40 Mark MARK-COSMOS PageOpen FullProgressDialog
2012/4/15:12:11:40 Mark MARK-COSMOS Installing DirectX® Runtime: C:\Autodesk\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/15:12:12:33 Mark MARK-COSMOS Install DirectX® Runtime Succeeded
2012/4/15:12:12:35 Mark MARK-COSMOS Installing Autodesk® Maya® 2013: TRANSFORMS="C:\Users\Mark\AppData\Local\Temp\_AI7BF4.tmp\x64\Maya\Maya2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Maya_2013_English_Japanese_SimplifiedChinese_Win_64bit_dlm\" INSTALLDIR="C:\Program Files\Autodesk\Maya2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/15:12:12:45 Mark MARK-COSMOS Install Autodesk® Maya® 2013 Failed Installation aborted, Result=1603
2012/4/15:12:12:45 Mark MARK-COSMOS Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
______________________________________________________________
Any help would be appreciated.
Problem solved !!
After speaking to Autodesk Support, I was asked to clear out any temp files, so that a clean LOG file would be generated and then posted on to Support when the next installation failed.
My process was :
- Manually delete the PIC file (needed to un-install the one package I was able to install)
- Un-install MAX via Revo Uninstaller, including a scan to mop up any remaining files.
- Carried out a file search for “*.temp” and “*.log” on the C-Drive and manually deleted anything that looked as though it belonged to any Autodesk product (there were several).
- Run a system clean up with CClean.
- Re-install MAX 2013
- ….. and then re-install Maya 2013
- It worked.
As deleting the “temp” and “LOG” files were the only thing I did extra to the previous half a dozen attempts, I can only assume that the problem was in one of these rogue files.
Hope this helps someone else.
